gtxdude
Took booster off 65 and going to manual disc set up, I thought I could remove rod from booster and use with new MC but it doesn't look right. I have some pics, neither the top rod going into booster or bottom lever that went through wall to brake pedal look like they will work. Do I need to get a rod and if so what length does it need to be and where can I get one? thanks
p.s. do I need a rubber boot for fire wall with rod?
