Brakes now......
moparlee
64 Valiant
Joplin, Mo
.....I'm working on the brakes again to finish it up this time hopefully. Found that the master was leaking out the back, and that the 74ish prop valve wasn't what I was needing for 4 wheel disk set up. Doctor Diff(Cass) set up with the right prop valve and a master. I'll take a shot of the block and post that.
I'm going to not run the adjustable right now if I can get a way with it.
Thats the master cylinder I want to run (85 5th ave) when I do my disc brake swap for the front. Which adapter did you use? I want to use the ae one since there the only one that says you can use the stock push rod.
My adapter is the Mopar Performance one, to be honest there are a lot nicer ones out there. I ended up buying an aftermarket rod and shortened up some. It was already two piece.
