64wagon
Hi guys all these parts are brand new in the box, maybe someone can save a couple of bucks and i can get a few bucks for something else.
1) P5007742 These heavy-duty billet aluminum CNC machined Rocker Shaft Stands use standard rocker shafts and rocker arms. For Mopar Performance Stage VI heads P4876383 and P4876386 these go for $199 froms Jegs, heres the kicker i lost one of the large square blocks, it wouldnt take much to make one, $50
2) P5249559 Mopar Performance Small Block 8 blade water pump fits 1970-Up $70
3) P5153823 Mopar Performance Big Block Aluminum Stage VII Raised Port Heads Pair $1169 each at Jegs, i will take $1500 for the pair
4) P5249189 New in the Box Aluminum Intake manifold Spacers for use with Mopar performance LAuminum Stage VI Heads P4529335, Just bolt these heads on your 383/400 low-deck block, then bolt up a stock 440 ("RB") manifold suing these spacers. Read more at http://www.allpar.com/history/mopar/performance/heads-for-dodge.html?ktrack=kcplink Jegs $165 i will take $100
5) Milodon 18650 Oil Pick Up for 318 and 340 motors, stock replacement pickup for use with a factory mid sump oil pan or the Mildon 30750 pan $32 jegs i will take $15
6) P5007816 Mopar Performance Big Block Oil Pan 8 Quart Center Sump New in the Box Jegs $178 I will take $100
email me if you have any questions
