Matts440
Okay is there a trick to these I can't get mine to lock into place on my billet cam. The gears aren't meshing, I have the milodon hardened shaft with brass gear.
Yep tried it slowly and a screw driver on the gear and can't get I to drop down more.
New bushing or the original?
Are you sure you have the correct shaft Milidon makes a longer one for there pump with the external line, are we talking RB, B, or A. Did you check them side by side with the O.E. one?
Brian6pac thank you for the help, thought I was loosing my mind, didn't remember it being this hard when I built my 440 years ago lol
looks like the gear is upside down to me !!
Hughs has the steel geared ones for a roller cam ----
