Brownies
RedFish
This could have been a rant if I hadn't found it so funny...
My wife mail ordered this fancy new brownie pan. It is advertised as non-stick, includes divider, yada yada. The greatest thing since the snuggie ? Anyway, The instuctions included say line the pan with aluminum foil, spray non-stick product like PAM on both the foil and the divider, then lightly coat both with flour. ROFL
Sure enough the brownies fell right out in nice little squares ( took 5 to get my fill ).
I believe I could have got the same results from my 67 cuda grille inserts.
Bottom line, if you plan to order one of these pans I suggest you wait. Maybe next years model will include a snap on cover.
I've seen those commercials RedFish ... seemed like an awful lot of hassle (and a bunch of extra dishes to wash) just to avoid having to dirty a knife to cut them into pieces.
If it's advertised as non stick, why the PAM???
LMAO @ using your grille inserts instead.
Non-stick, then Pam and foil.. woo boy. Sounds like the one that guarantees to kill all mosquitos within two blocks. And you get 2 pieces of 2x4.
Grant
