Budget magnum intakes?
Cuda416
South, TX
I've seen the PC units (same part?) and of course the Edelbrock ones. Any opinions on the Speedmaster units? Not much cheaper than the PC's but $20 is @20 ...
best budget magnum intake will be 2nd hand.... watch the sale adds here, and ebay
My Speedmaster dual pattern LA/Magnum,fit was iffy.I tried it anyway, Vacuum leaks, wouldn't idle, car ran crappy,ditched it for a used Edelbrock problem solved.
I bought the pro comp one when I did my 5.2 swap-leaked coolant...replaced with Edelbrock, problem solved.
Sometimes you can find a decent deal on the Edelbrock one if you're not in a big hurry. Dont remember for sure where I got mine, but after some internet shopping I found it significantly cheaper than Summit or Jegs price.
