Yeah, gotta have deep pockets to pay somebody to build that, not to mention the custom parts design & mfr.,........but somebody does!Very interesting stuff. I wonder what the price tag was? I'll bet it was astronomical.
Not sure why you would go through so much effort and knowingly choose a block with fewer mains.
The guy at 12bolt.com has been doing turbo'ed straight six's for awhile.
What are You willing to spend? Those engines were a mess head-wise, there was a lot more to be gained on avg in that case.they can get a custom head for THAT? then whats the holdup on getting one made for our engines?
So an established & renowned NAPCAR engine builder thought it was such a concern that He saw fit to cut the mains down and the rod journals decreasing overlap w/o even increasing stroke, AND putting boost to it, AND stating it'd do 700+ if they wanted it to.......
4 vs 7 mains in an inline 6 depends upon where the engine design group is placing more importance.I admittedly am still learning but when I was building a nitrous motor it was explained to me that you are basically putting a lot of force on the crank pushing it out the bottom of the motor. Boost would be doing the same thing no? Not sure if you are saying why I would question a renowned builder or if you are agreeing. Im just a guy listening to what the guy said. He brought attention to the fact that they were choosing a motor that had fewer mains. RRR said it was no big deal. I believe you are saying the same. Great, its no big deal. Logically to me...Id probably go for more mains. Shed some light on me and explain how fewer mains is no big deal when dealing with those type of power levels. Im open to it.
There are a number of parameters in play here. First up, V8s only have 5 mains, so there are more mains/cyl in a 4-main 6cyl. If the main dia & rod jornal dia are sized right, there is overlap & rigidity, but there is more friction. There is more room for wider, heavier, & thus stronger throws for a given alloy/mfr.....but it is much heavier, & needs to be. If quick rev response up & down is the goal, lighter is better, not a real problem for a turbo'd mill primarily aimed at the drag-times & pulling. There's also the inline evil of crank twist because of the shaft length, here the amount of mains can reduce off-axis deflection when there is enough load or the onset of detonation, but there is also a less forgiving/shorter stress path w/7 mains. In other words, it may not deflect, but may break....sort of like forged vs cast, stronger will flex more vs less strength more rigid...most of those old forged cranks were overkill, to their detriment, as long as the block & mains can handle the load they're good. The center cap work on those old blocks is enough to take a bunch.....hope that made some sense....I admittedly am still learning but when I was building a nitrous motor it was explained to me that you are basically putting a lot of force on the crank pushing it out the bottom of the motor. Boost would be doing the same thing no? Not sure if you are saying why I would question a renowned builder or if you are agreeing. Im just a guy listening to what the guy said. He brought attention to the fact that they were choosing a motor that had fewer mains. RRR said it was no big deal. I believe you are saying the same. Great, its no big deal. Logically to me...Id probably go for more mains. Shed some light on me and explain how fewer mains is no big deal when dealing with those type of power levels. Im open to it.
What about my statement needs correcting? Just a guy here, but I dont believe I stated that 12bolt had a hand in the build. Carry on.Just so you are corrected, 12bolt.com had absolutely nothing to do with that turbo truck in the video you posted above. That truck and engine was constructed and fully machined by the truck owners in Texas, the Staph Brothers. They are also featured in Leo Santucci's book showing all their details and machine shop they own.
In reference to the mans own words @ 5:20 in the video....Not sure why you would go through so much effort and knowingly choose a block with fewer mains.
ooooooohhh My apologies CNC dude. I am mistaken. Now Im dumb. I get it now. grovel grovel grovel......Just so you are corrected, 12bolt.com had absolutely nothing to do with that turbo truck in the video you posted above.
Nevertheless, that's a badass truck, thx for linking...ooooooohhh My apologies CNC dude. I am mistaken. Now Im dumb. I get it now. grovel grovel grovel......
Yeah, that helps the sting of being stupid. Thanks Killer6! Man....this crow is delicious! ugh.Nevertheless, that's a badass truck, thx for linking...
You are not stupid at all, I've seen a lot of your posts in the past and would never try to imply that towards you or anyone else. Yes, it's a killer truck. It would be nice to see someone with a Slant build one to that extreme if money was no object. LOLYeah, that helps the sting of being stupid. Thanks Killer6! Man....this crow is delicious! ugh.
