build sheet questions
Jmcginnis89
Missouri
i found the build sheet for my plymouth gold duster under the back seat should i leave it or put up ?
the build sheet should be taken out and put in a plastic sleeve as they are irreplaceable documentation. unless you have found more in the car and no one will be sitting in the back seat it wouldn't matter
I found two in my 73 dart swinger one under back seat and one on top of glove box insert ! Is this usually ?
Yep, they could be anywhere. Some under the rug, also have been found in the headliner. Glovebox and back seat most common.
Once you remove it, a good idea is to make a good colour copy of it, then keep the original in a sealed plastic cover. - Dale
Mine both in plastic now ! Glove box one got a few tears in it ! Other one in good shape , not bad for 40 yr. old paper !
Put it up. They are Most common in seats or on top of glove box. Most cars have 1 or 2.
