Lars
I've built a basic 360 bottom end using ARP main bolts (kit# 140-5001). Using my factory main caps and a Melling standard pump, I ran into an interference problem with the pump on the rear main bolts. On the bright side I called ARP and they are trying to make it right and are sending me two 12-point headed bolts that are .070 shorter, but we aren't sure it's going to clear. I won't get them until next week (great, more delays), but I just wanted to post up here and see if anybody else had run into this problem.
