66/440
Active Member
Hi everyone. so im looking to build a 451 stroker but need cam help. ive already got a steel 440 crank, some eagle h beam rods, performer rpm air gap intake 440 source stealth heads with port work done by modern cylinder head over in michigan, harland sharp 1.5 roller rockers and i plan to buy some diamond flat tops. i'd like to run 3.55 gears and a 2000-2500 stall because this will be a street motor. so my dilemma is i need a hydraulic roller cam that's streetable but will still put me a little ways over 600 hp and 560+ lbft of torque. any suggestions?
