[SOLD] BUILT 360 engine ALL NEW PARTS
surfer121
SoBay Calif
Built never run 360 Mopar small block $7600
Used parts
Block-- .030 over, 0-decked, line-honed, blueprinted and detailed, brass plugs.
Crank--Maged,prepped,polished
New parts
Milodon A-body oil pan&pump Mopar windage tray
Clevite main & rod bearings
Felpro gaskets
ARP studs
Eagle H rods
KB hyper-eutechic pistons seal power rings
Isky cam -lifters-pushrods
Cloyes dble chain set
Mopar FP ecentric and oil pump drive shaft&gear
Carter fuel pump and hard lines
Mopar timing cover and water pump
Mopar fan and clutch assy
Balancer and pulleys
Altenator
Edelbrock alu heads
Hard chrome shafts and Isky Rockers
ARP head bolts
Edelbrock AIR GAP manifold
Holley 750 carb
Mopar Ignition set with Mopar/MSD 6al box
Mopar valve cover and air filter
Taylor wires
B&M flexplate
rotateing assy external ballance
Schumacher engine mounts
some final assy required
will disasemble for a fee applicable towards purchase
Located Gardena Ca.
Atlas Engines in Harbor City did the block machine work (Rob Weisner)
I detailed the crank and had Velasco mag & polish it , Was down there picking up my Dragster crank anyway
Engine Dynamics did the full assembly balance
I will buy an engine stand and secure it to a pallet and box it up, There are engine shipping services out there to get a quote
DRE Fab
17000 s vermont ave
gardena ca 90247
business with forklift
I will be at Woodly Park Spring Fling (SAT)Swap-Meet with the engine for those that want to look at it
