Bulkhead Connector Terminals?
Electrical and Ignition
  1. coalman
    coalman Well-Known Member
    1,141
    257
    Aug 6, 2015
    Texas
    Local Time:
    1:50 AM
    Anyone ever remove the male terminals from above? Looks like an impossible task. Thanks
  2. cudascott
    cudascott Now I have a Hemi
    1,810
    661
    Jan 11, 2012
    TN
    Local Time:
    2:50 AM
    Don’t see a pic but it’s very easy to remove the terminal ends from a bulk head connector. If you look
    close there’s a small rectangular notch in the hole where the male terminal pushes in. Buy or make a tool that fits that notch and you then insert the tool which in turn depresses a small retaining tab that’s part of the terminal end and it will pull right out.
    • Agree Agree x 1
    • cudascott
      1,810
      661
      Jan 11, 2012
      TN
      Local Time:
      2:50 AM
      Here’s a pic to help you see the small tab that has to be pushed in with the tool. B442C4DC-1E2E-4049-B1DD-619643AFEE70.jpeg
      • Agree Agree x 2
      • Like Like x 1
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        46,446
        14278
        Oct 14, 2010
        Idaho
        Local Time:
        11:50 PM
        Push the tang sideways as depicted by the arrow Small screwdriver etc Sometimes the ones with heavy current like the ammeter will heat up and melt into the plastic. All you can do then is try and re-heat them like maybe with a soldering iron, to soften the plastic and let them out. You may destroy them in process
        • Like Like x 1
        • cudascott
          1,810
          661
          Jan 11, 2012
          TN
          Local Time:
          2:50 AM
          Yea like Del shows I missed the male part:lol:
        • A56
          A56 MoParAffliction FABO Gold Member
          2,780
          4417
          Jun 24, 2014
          South of the Mason-Dixon Line
          Local Time:
          1:50 AM
          We used to use a paper clip, unfold it, file or tap one end flat and there ya go.....carefully
        • coalman
          1,141
          257
          Aug 6, 2015
          Texas
          Local Time:
          1:50 AM
          Thanks, it is a real pain. Yes the female one's are easy. I am going to replace the top connector as one of the locking ears is broken I might just cut them out carefully...
        • BillGrissom
          BillGrissom Well-Known Member
          7,440
          427
          May 10, 2009
          Sacramento
          Local Time:
          11:50 PM
          The male terminals are on the cable connectors. Needle-nose pliers with angled tips let you compress them right at the bottom locking tab. First pry out the felt insert for more room. I have a tool like needle-nose w/ U-channels at the end which let me press the sides without slipping off. You can buy new ones. They are termed "56 Terminal" or "Packard 56" (electronics manufacturer, not the car). GM also used them in the 1960's. They come is sizes for different wire gage ranges. Search ebay.
        • coalman
          1,141
          257
          Aug 6, 2015
          Texas
          Local Time:
          1:50 AM
          Thank you, I have some of the terminals, I will try again to take them out.
        • crackedback
          crackedback FABO Gold Member FABO Gold Member
          18,831
          3237
          Aug 7, 2005
          92201
          Local Time:
          11:50 PM
          I slide a narrow screwdriver into the connector and compress that male lock tab.
        • coalman
          1,141
          257
          Aug 6, 2015
          Texas
          Local Time:
          1:50 AM
          Got them out thanks, what a pain in the bottom, that is why it is a hobby car...
          I got my new male bulkhead connectors and replaced the one with the broken locking ear. They didn't come with the felt on the inside, is that an issue? Thanks
        • CRUZE 418
          CRUZE 418 FABO Gold Member FABO Gold Member
          419
          155
          Mar 11, 2019
          Illinois
          Local Time:
          1:50 AM
          Felt or rubber? It's a seal.
        • coalman
          1,141
          257
          Aug 6, 2015
          Texas
          Local Time:
          1:50 AM
          Felt I think, not rubber.. Thanks
        • coalman
          1,141
          257
          Aug 6, 2015
          Texas
          Local Time:
          1:50 AM
          Got some felt from Hobby Lobby , made one.
        • BillGrissom
          7,440
          427
          May 10, 2009
          Sacramento
          Local Time:
          11:50 PM
          I squirt silicone di-electric grease into the female bulkhead terminals, indeed all connectors in all my cars, but especially important for those that might see water.
          • Agree Agree x 1
          • coalman
            1,141
            257
            Aug 6, 2015
            Texas
            Local Time:
            1:50 AM
            Thanks for the tip.
          • CRUZE 418
            419
            155
            Mar 11, 2019
            Illinois
            Local Time:
            1:50 AM
            Foam rubber.
            • Agree Agree x 1
            • coalman
              1,141
              257
              Aug 6, 2015
              Texas
              Local Time:
              1:50 AM
              Yes I agree on the material I found the small ones too, I am checking to see if they are cut for the male terminals. Thanks for response.
            • 4spdragtop
              4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
              30,381
              10943
              Aug 28, 2009
              Wasting time here
              Local Time:
              1:50 AM
              Originally male terminals had them as well. Havent looked for repops. Not there yet.
            • cudascott
              1,810
              661
              Jan 11, 2012
              TN
              Local Time:
              2:50 AM
              Detroit muscle has them
              • Thanks! Thanks! x 1
              • coalman
                1,141
                257
                Aug 6, 2015
                Texas
                Local Time:
                1:50 AM
                I sent them an "E" mail, I guess I will call them Monday. Thanks
              • coalman
                1,141
                257
                Aug 6, 2015
                Texas
                Local Time:
                1:50 AM
                I ordered a set this morning from DMT, the cutouts are supposed to be in them...
