So if all of the lifter holes were bushed, would you have to do any other oiling mods to run a solid roller in a 360 block?? How would the lifter get any oil then? Just run back oil?
The bushings have holes drilled in them prior to install to feed the body and pushrod seat with oil. The lifter face and lobe are splash fed oil from the crank.
