c 16 jetting
ian
hi going to run 150 nos with c 16 , run pump fuel normaly ,is there jetting change for c 16 fuel. thanks this is my combo 360-1 cnc flow343 @ 600 intake 225 ex @600 ,indy intake, t d 1.6 rollors. , 410 cube ,11.8 comp ,259/265 @ 050 109 l/c 3 degee advance .200 figures are 176 in 171 ex solid flat tappet 5000 stall trans brake 904 , 3.9 gears 26/10/15 slicks 3500 lbs. what times do you guys think it has in it .racing this sunday 1/4 mile
You don't have enough compression to run that high of octane of fuel, even with the NOS. C-12 would be better, and you may be able to get away with 100 octane.
How much lift are you running?
635 lift on in and ex may end up with 200 shot , i aso have a 102 octaine un leaded fuel witch i use as a boaster with our pump fuel. thanks ian
c-16 specific gravity is way to much to run without lots of compression, I have 13 1/2-1 and my car went slower with 16 even with 2 jets richer !
I run c-14 on the track when shifting at 7800 but on the streets I run c-12 with no problem
c-23 is Great for Nos cars !!
now if you meant Q-16 not c-16 then go for it, the extra o2 in this blend is good for all race motors !
