Caliper rebuild lube
nothingbutdarts
Bailey, Co.
Years ago when you bought caliper rebuild kits they would include a little tube of assembly lube. Not these days, what is a good lube to use on the o-ring and metal puck when reassembling?
Well, you can just use brake fluid, as the lubricant, or this stuff works well, for auto mechanics.
But it will take you a bazillion years to use it up if your not a professional mechanic, doing brake caliper rebuilds, on a daily basis.
Wow, Thank You!
Got some in the mail today! Thanks again!
