Caltrac’s and high rpm doesn’t mix
Mopar Racers Forum
  1. o1heavy
    o1heavy 1974 dart sport
    882
    305
    Jan 7, 2009
    tarkington
    Local Time:
    12:12 AM
    We are getting somewhere now
    Added weight leaving at 4300rpm
    • Like Like x 6
    • skrews
      skrews Well-Known Member
      1,578
      1120
      Jul 20, 2012
      Washington state
      Local Time:
      10:12 PM
      Looking better.
      • Agree Agree x 1
      • '63GT
        '63GT Well-Known Member
        1,482
        1525
        Jun 9, 2018
        Turlock, CA.
        Local Time:
        10:12 PM
        Yellow Rose is spot on!
        Your car is leaving, 'neutral'.
        When you installed your CalTrac's, did you tighten the front spring eye bolt down 'tight', or did you leave 'slack' in it? There HAS to be slack in the mechanism or the CalTrac's won't work properly, they will bind up.
        The Nyloc nut supplied is not to prevent the nut from backing out, it's to allow freedom in the front eye, so that the bars will work.
        • Agree Agree x 1
        • '63GT
          1,482
          1525
          Jun 9, 2018
          Turlock, CA.
          Local Time:
          10:12 PM
          Of coarse there's a limit to everything... Steve Wann likes to run it loose too. Too loose in this run against John Winslow at Bakersfield.
        • o1heavy
          882
          305
          Jan 7, 2009
          tarkington
          Local Time:
          12:12 AM
          Removed the 85lbs reset bars to a nickel gap and we are back to the bouncing the tire
          Tighten the rebound doesn’t seem to help
          Only thing it does is stop the separation
          Man what a pain in the ass these things are
          I will drop the rear tire air pressure this weekend just to see
        • Toluene56
          Toluene56 Well-Known Member
          912
          687
          Nov 9, 2009
          reno
          Local Time:
          10:12 PM
          I'm probably wrong.. but wouldn't you want to loosen the rebound and tighten compression. That way when it hits the tire it keeps the pressure on it and promotes separation? I'm trying to learn all this fancy shock tuning stuff. Lol.
        • '63GT
          1,482
          1525
          Jun 9, 2018
          Turlock, CA.
          Local Time:
          10:12 PM
          The guy I mentioned in Post 79 runs 1/2 to full turn of preload on the car in the video.
          Starting point is zero. Just tight enough, where you can still move the roller on the spring.
        • mopar65
          mopar65 Well-Known Member
          1,903
          1694
          Mar 23, 2008
          Laquey MO
          Local Time:
          12:12 AM
          Hey Joe sorry to hear all about all the trouble you are having. I can't add much but maybe ask Jason Teague how he has his duster set up. He has a 71 plymouth duster with a gen 3 N/A Hemi with caltracs. I know he is useing a transbrake. But I don't remember what shocks etc he is useing.
          • Like Like x 1
          • o1heavy
            882
            305
            Jan 7, 2009
            tarkington
            Local Time:
            12:12 AM
            N
            I’ll ask him. But I believe he is leaving at a lower rpm.
          • o1heavy
            882
            305
            Jan 7, 2009
            tarkington
            Local Time:
            12:12 AM
            527D645A-3432-4F28-BD76-7E13B9C39BAC.jpeg https://youtu.be/6Tq1_Uql5Gs
            Ok just Incase anyone else can use this info
            This is the spring relocation boxes from US cartool has 3 different front spring mounting locations
            I went from the top hole to the very bottom
            Which raises the rear of the car but should lower the instant center
            Went to a pro bracket radial
            And have roughly 10 passes on the since the
            Changes and 10 passes have been perfect
            According to the 60 and the video ,
            I have been leaving at 4500 all weekend then and after I was put out of the race this weekend I put the two-step to 5000 which is the video I posted .
            Which help of Jeff w8/904 combo guy
            I believe I’m actually making some progress
            • Like Like x 2
            • Thanks! Thanks! x 1
            • o1heavy
              882
              305
              Jan 7, 2009
              tarkington
              Local Time:
              12:12 AM
            • ValiantRacing
              ValiantRacing Well-Known Member
              426
              300
              Jun 12, 2009
              El Dorado Ca.
              Local Time:
              10:12 PM
              Was that in 2012? i was there that year, and they had to change the oil pan.
            • '63GT
              1,482
              1525
              Jun 9, 2018
              Turlock, CA.
              Local Time:
              10:12 PM
              2011 Divisional in Bakersfield.
              See if you can spot yourself below..
              • Like Like x 1
              • ValiantRacing
                426
                300
                Jun 12, 2009
                El Dorado Ca.
                Local Time:
                10:12 PM
                I did see myself , i thought is was 2012
              • '63GT
                1,482
                1525
                Jun 9, 2018
                Turlock, CA.
                Local Time:
                10:12 PM
                lol no kidding ?? where? (time)
              • ValiantRacing
                426
                300
                Jun 12, 2009
                El Dorado Ca.
                Local Time:
                10:12 PM
                4.30 next to Orange Demon
              • '63GT
                1,482
                1525
                Jun 9, 2018
                Turlock, CA.
                Local Time:
                10:12 PM
                OH !? you were talking to John Gray.
                Larry Gilley at 5:10 talking to Don Wann (RIP)
                • Like Like x 1
                • 70aarcuda
                  70aarcuda Master Hoader of SBM FABO Gold Member
                  15,744
                  4279
                  Jan 16, 2005
                  las vegas
                  Local Time:
                  10:12 PM
                  AT 3.03 Dad's Barracuda Earl Blake....my neighbor...
                  • Like Like x 1
                  • Jadaharabi
                    Jadaharabi FABO Gold Member FABO Gold Member
                    7,722
                    8467
                    Jan 8, 2016
                    Peoria, Illinois
                    Local Time:
                    12:12 AM
                    @63GT
                    Did you record that vidio?
                  • '63GT
                    1,482
                    1525
                    Jun 9, 2018
                    Turlock, CA.
                    Local Time:
                    10:12 PM
                    No, Toby Lang did that.. Nice that he took the time to give us an inside scoop !
                    Especially since I didn't make that event... (but heard ALL ABOUT IT lol)
                    • Like Like x 2
                    • RockinRobin
                      RockinRobin Well-Known Member
                      719
                      203
                      May 15, 2013
                      Liberty Hill, Tx
                      Local Time:
                      12:12 AM
                      I am also an N/A gen3 hemi but I footbrake and leave at 1500rpm.
                      For what it's worth the front is right down on the bumpstops and tire pressure is 12.2 on 12x29.0 Hoosiers. 60' is 1.45. Calvert 90/10's on the front and Calvert single adjustable on the back about 1 click from full loose.
                      slant 6 torsion bars up front and stock 318 leafs in back.
                      I see you are in Houston. Do you ever take it to Little River?
                      • Like Like x 1
                      • o1heavy
                        882
                        305
                        Jan 7, 2009
                        tarkington
                        Local Time:
                        12:12 AM
                        Thanks for sharing .
                        If you were asking me about little river .
                        I haven’t been to little river yet
                        I usually stay local, Evadale, pine valley and Hmp
                      • RockinRobin
                        719
                        203
                        May 15, 2013
                        Liberty Hill, Tx
                        Local Time:
                        12:12 AM
                        I love Pine Valley but haven't raced there in about 3 years.
                        I thought Evadale was closed.
                      • o1heavy
                        882
                        305
                        Jan 7, 2009
                        tarkington
                        Local Time:
                        12:12 AM
                        Same guy That is Running pine valley is running Evadale, pretty good index program
                        check out the Facebook page and come join in on a index race. 7.0 or a 5.80
                        To choose from , the payout is usually good depending on the car count .
                      • RockinRobin
                        719
                        203
                        May 15, 2013
                        Liberty Hill, Tx
                        Local Time:
                        12:12 AM
                        good to hear that Evadale is still open. I tried a 6.60 index once but just couldn't get the pro tree since I was footbraking and setup for sportsman tree. Had terrible lights like .1 or .12 and was in the trailer in a hurry.
