RAYS 69 MOPAR Well-Known Member Joined Dec 8, 2007 Messages 262 Reaction score 41 Location los angels Feb 20, 2008 #1 Hi I Just Put In A Erson Cam In My Small Block I Would Like To Know Do I Have To Change The Dist. Gear???its A Flat Tappet Hyd Cam
340demon old man Joined Apr 9, 2006 Messages 240 Reaction score 45 Location Ocean Shores, Wa Feb 20, 2008 #2 do i have to NO but is good idea to change most grinders will not garranty the cam if you do not change to dist gear
RAYS 69 MOPAR Well-Known Member Joined Dec 8, 2007 Messages 262 Reaction score 41 Location los angels Feb 20, 2008 #3 What Is A Good Gear To Bye??
Johnny Dart Well-Known Member Joined Nov 30, 2006 Messages 8,790 Reaction score 4,106 Location So Cal Feb 20, 2008 #4 Unless your dist is old and worn out you are fine. Plug that bad boy in and go. In fact if you dont have electronic ignition,now would be a good time for the Mopar Performance kit.
rumblefish360 I have escaped the EVIL Empire State! FABO Gold Member Joined Jun 21, 2005 Messages 49,813 Reaction score 23,732 Location Florida Feb 21, 2008 #5 I never heard of a need to change a gear for warranty. I never did. Never a problem.
dustertogo Well-Known Member Joined Mar 7, 2006 Messages 880 Reaction score 209 Location Brandon, MS Feb 24, 2008 #6 You may be referring about the need to replace the steel distributor drive gear with an aluminum/bronze gear when installing a roller cam.
