Romulo Roderiques
I purchased a solid cam and lifter kit from Summit for my 65 Dart back in December. It’s on a huge back order. Anyone know any other good sources that may have one available? TIA
I ordered a Howard’s cam Summit that was listed with a date a few months away and three days later, it was on its way. Call the cam company direct and ask questions. The phone call cost is peanuts but the instant answers if they have a code to grind are priceless, time saving, exact cam wanted freshly ground, etc….I purchased a solid cam and lifter kit from Summit for my 65 Dart back in December. It’s on a huge back order. Anyone know any other good sources that may have one available? TIA
What year and engine size do you have. I don’t know even know what exactly I should order from Howard’sI ordered a Howard’s cam Summit that was listed with a date a few months away and three days later, it was on its way. Call the cam company direct and ask questions. The phone call cost is peanuts but the instant answers if they have a code to grind are priceless, time saving, exact cam wanted freshly ground, etc….
Boom! You Win!Call Jim at Racer Brown. He will hook you up.
I’m currently working with a ‘97 - 5.9What year and engine size do you have. I don’t know even know what exactly I should order from Howard’s
Boom! You
I’m keeping everything stock none of the pushrods are bent. Thanks for the info.I’m currently working with a ‘97 - 5.9
You can call Howard’s or any cam company and ask for there help. When ordering a cam, the entire kit is often a smart way to go since the valve springs are matched to the cam and then the retainers and locks can also be purchased as well for the valves in the engine. So in one shot, you’ll get the cam, lifters, valves springs, retainers and locks. Measure for the pushrods. If you don’t have a pushrod measuring rod, that can be ordered from most cam companies. I got mine from Comp Cams. Then you’ll need a caliper able to measure them. I picked up a 12 inch caliper from Power house.
Not at all. I was going to call them next week. Do they just grind down the old one or what?@Markh
Do you have any experience with the grinders you disagree to use that I posted?
Not followin you.750 roller.
That's was directed at Markh.Not at all. I was going to call them next week. Do they just grind down the old one or what?
He's just another forking troll.@Markh
You listed two very good cam
MOPAROFFICALNot at all. I was going to call them next week. Do they just grind down the old one or what?
Short answer...no...That's not a factor. Just tell them what gear, trans, and what mannerism/rpm range you'll be driving in... say... idle to 6000rpm...then you can choose the carburetor 'cfm' based on that range..whether 2 or 4 brl.Question. Since this used to be a two barrel carb engine but now it is has a four barrel intake and carb, should I be looking for specs on a cam set up for a four barrel or still a two barrel ?
