remytherat
Need to replace the cam bearings on my 5.9 magnum. Would prefer to do so with the bottom end installed. Is this possible?
This is what I’m working with.
I hear you about the clearancing. The only thing I can think of is just to cross my fingers if I keep the bottom end in.
Always wonder why cam bearings lose chunks like that.. mine had a few small chunks missing.. i would like to tell you that i changed them... but....
Well that makes senseAcid in the oil, they break down over time. Sitting long periods of time (years) is hard on them too.
Just a guess > valve spring pressure pushing on them 24/7 when sitting for long periods, without being turned over eventually the oil film goes away...
Really? They are my preferred MFG. Especially their coated line. J.RobDo not use Durabond brand?? QC is terrible.
Yes.Need to replace the cam bearings on my 5.9 magnum. Would prefer to do so with the bottom end installed. Is this possible?
