Yes was supposed to be same cam group last time. 2 stock grinds a KV2 cam and KV3 cam and said could be made on 110 or 108 but recomended for my 422 with my converter, gear, compression 110.You said there “Both - custom grinds.”
Is one supposed to be a copy of the other one?
Bang on and bulls eye.They may have developed a master lobe of very similar specs between the two cams you ordered and just used that for the second cam since it’s only a few degrees different. You Will absolutely NOT notice any difference in those two cams. I promise.
