I just installed my cam and with the sprockets at Dot-To-Dot, the centerline comes out at 109 which matches the cam card separation angle.
The card says to degree it in at 105.
Do I just advance the cam sprocket 2 degrees and check the centerline again?
Thanks!
Thanks!
