earthmover
in the tire smoke
Bobby I had talked with you a while back and we came up with me useing the xtrem cam from comp I think it was 282grind 520/540 its cut on a 110 I think I'm right now I have been looking at some of the mm cams and was thinking how would this work for me short run down on the build
j heads mild port work 240 at 500 I think it was
30' 340
dome top pistons (about 11.5.1 comp) on h beam rods
stock crank turn
x cel intake ( may change soon)
950hp carb
I have 15/8 or 1/3/4 headers
727 rev val body
91/2 (lupo) verta 4500 / talk to lupo and plan to go to a 8'' 904 soon as well
834/ rearend with 4.57
27.5/10 qtp going to 29 next time
ss springs and mp drag shocks in back /3way adj in the front
mp dist locked out and 6almsd
8gal fuel cell and 1/2 line to the front
I'm still thinking about the xtrem one just saw the mm in mopar mag around the same lift but cut on a 106or 108 ..any ideas and thanks for all the help Bobby.....plan to give you a call in the next few days ....:read2:
30' 340
stock crank turn
950hp carb
727 rev val body
