I got a new Lunati flat tappet cam and this came with it. There is only 5/8 of an once, not much for 16 lobes and lifters. The journals still need lube as well. I was going to use some Lucas or Ultra Slick for them.
I called the Comp tech line and the guy said if it was going to sit and it probably will for a few days, he said get some black grease and use that... black tube from O'Riley or Auto Zone. Is this what he means? I also have some nasty heavy, sticky black grease, nasty stuff,
I've use on throw out bearings as well.
While I'm at it,any suggestions on break-in oil?
Thanks
Thanks
