joes68340s
Just wondering if people with this crate motor have found a better cam.
He said stock create engine so that would be the MP Hyd. roller cam, 288/292 ... I forget.... low .500’s in lift..Any idea in what cam is in it now ?
I only asked about the cam as thought maybe there were people still running them, crate motor that is. I have a 390 stroker set up for 4 speed. Will be installing. Just wondered about cam for another project.
I just added you on IG. Can’t wait to see pics of that valiant!Been thinking about a 396" stroker myself. 360 block with a 3.79" crank. Is this how you're doing it? 318 base with a 4" crank?
BTW, Joe. You on instagram? I'm @5_points_racing . I don't have any Valiant content on there but it's coming very soon. Reiss Racing is doing the metal work now to fit 315's in front with a 335 rear.
Have you picked wheels for it. Ive been wanting to do a track day but I cant get the tires. Tire Rack dosent know when they will be in, somewhere in late spring. Maybe.
Here’s the one I plan on running. RAMM used the long snout version. I plan on using the short snout version in case I decide to put the magnum timing cover back on.Note that the links for Lunati's cams don't work anymore and you can't even find the cam cards on their site (!?)
IIRC one of their HR cams was slightly more lift at 1.6 but slightly less duration at .050 than the factory 380 HP cam.
Troy sold a ton of those at the old Westoaks Mopar Performance.
He said they weren’t great down low, but made good peak numbers (marketing) for a low compression 9.0:1.
Most people put them in cruiser type cars, but picked the 380HP because of the high HP number (marketing was right) But they were not a motor you could slap parts on without tuning and drive to the grocery store without any additional effort.
Typical 380HP buyers would have been happier with 320HP version. Eyes bigger than their stomach syndrome.
They were a little rough idle, not cold start friendly, and took carb and combination tuning to make them flawlessly around town stoplight friendly.
Honestly, my 416 stroker has too much torque down low and wipes out the rear tire in autocross. It doesnt help for smooth driving. One of the reasons I put a M1 single plane in it.
But the higher rpm HP on that 380HP crate would be great at the track. A more modern cam swap focused on area under the curve could be if help.
I look into custom cam person because of the low compression and specific intentions.
If it’s weak, it’s out of tune or hurt.
I’d just stick it with 4.10’s or greater, tall tires and a S/S converter from a top rate company. Screw the cam change.View attachment 1715644266
I think the cam works really well, especially with the stock magnum valve lift limit.
I was thinking of going a bit smaller like a 265 .500 mild roller or drop in a set 4.10-4.56 and stick with what’s there.
Dang. Was RT615+ supposed to be made in a 335 ?Im running 18x10s square with Hankook Ventus 285x35x18s. I could fit an 18x11 wheel square But I prefer the 285s. Now I have to wait for Tires. I am actually thinking of putting the car up for sale as I have been focused on My Drag car.
