dave ellis
Old guys
I have a can with 12° of overlap at 50. Anyone have a formula to figure out the normally advertised duration? It's a Hughs cam. Duration is given at .006".
Hughs cam he0914bl. It's an old cam.I don't think you have enough info. Is there not a part number on the cam?
Comp. used at least 4 different lift points for advertised duration..........just for hydraulics.Adv duration numbers vary among cam companies & the lobe design itself. Crane used 0.004" tappet lift, Comp 0.006", Ultra Dyne [ Bullet ] 0.0045".
