Mattmoto441
So i misplaced my 340 cam plate and bolts so I quickly stripped stuff off a old 318 , I believe it was a untouched engine. Is this the preferred method of cam plate install?
I just went and cracked another 318 apart and it's the same no hole in the bolt and 3 bolts with a slinger , that one I know it untouched it came outta a 79 van . That hole isn't under pressure it's just a drip hole . So I'm wondering if its plugged or must get oil from elsewhere. Like the 2 larger holes directly above themNo, either get the bolt with the drilled hole in the top passenger hole, or leave the bolt out all together... The timing chain gets its oil from that hole...
How to Assemble the Front of a Small Block
Of all the small block mopars I've disassembled, I've not found one with a hole in the bolt. I left the bolt out without issue, or I've put them back together as found without issue. You can drill a hole in it. I think the crank splash'n the oil around keeps things lubricatedI just went and cracked another 318 apart and it's the same no hole in the bolt and 3 bolts with a slinger , that one I know it untouched it came outta a 79 van . That hole isn't under pressure it's just a drip hole . So I'm wondering if its plugged or must get oil from elsewhere.
Yes you have it right.
If I had to do it over I wouldn't use a tensioner with a double roller. (not necessary with a good timing set) It was recommended to drill a 1/64" hole in the oil galley plug. I'm sure it's a oily mess under that timing cover but the deflector and front seal are doing their job.
No leaks.
Your chain is upside down.....If I had to do it over I wouldn't use a tensioner with a double roller. (not necessary with a good timing set) It was recommended to drill a 1/64" hole in the oil galley plug. I'm sure it's a oily mess under that timing cover but the deflector and front seal are doing their job.
No leaks.
Its like a hurricane in there while the engine is running . With oil instead of rain .... I am sure the chain gets ample oil with or without a hole in the bolt .
Interesting that the tensioner plate in your last photo has a hole on the right side aligning with the oil galley plug.Used the dripper and replace the solid bolt with the bolt with the hole. Older double roller motors came with the hole . Newer motors came with a dripper and were oiled by the excess oil from the cam bearing run off.
Using both, bolt with hole and the dripper is just double oiling which is a good thing. I myself use the dripper and the bolt with hole on all builds. I also use the plate with the chamfered plate SP.
Tensioners are junk they were installed as a bandage on newer motors with cheap chains and inconsistent cam to crank spread. Throw the tensioner in the garbage they sell different length chains for this reason if your line bore is to deep. If you need a tensioner on your motor you need to get a better chain. pushing in on the slack side lengthens the pull side which changes cam timing. Sometimes you have to think of why mopar would do the tensioner . It was to absorb the cost of fixing the cam to crank spread. Much cheaper then redoing it right.
Ill disagree with that statement. The tension (pull) side is just that, under tension so there is no slop there as its fighting resistance from the valve train. Look at a bike or motorcycle chain under load, its straight. By taking up the whip of the slack side, your doing nothing to the timing except controlling the deceleration portion whip where the crank may overrun the cam speed and tension the slack side for a moment, there is your timing variance. Load the valve train up and shake the slack side, nothing is going to move. I'd run a tensioner and I'd even run a stronger silent type chain on it with its smooth back: nothing to dig a groove into the teflon slipper and about 200% more contact area on the cogs.... pushing in on the slack side lengthens the pull side which changes cam timing.
If there is slack on the tensioner side It has to come from chain stretch. If the chain is loose That means the pull side has to be longer. If it is longer that means there is a change in timing. Take the tensioner off and push one side then the other. You will see the cam sprocket move. Movement is timing change. It's a no brainer if you really think about it. I am only stating what I see after seeing many motors done at our shop.Ill disagree with that statement. The tension (pull) side is just that, under tension so there is no slop there as its fighting resistance from the valve train. Look at a bike or motorcycle chain under load, its straight. By taking up the whip of the slack side, your doing nothing to the timing except controlling the deceleration portion whip where the crank may overrun the cam speed and tension the slack side for a moment, there is your timing variance. Load the valve train up and shake the slack side, nothing is going to move. I'd run a tensioner and I'd even run a stronger silent type chain on it with its smooth back: nothing to dig a groove into the teflon slipper and about 200% more contact area on the cogs.
I'm surprised my Dakota didn't have a tensioner. It could have used one. Probably the original chain. I think it had 150,000 on it when it started slapping the cover. Time for a new one.If there is slack on the tensioner side It has to come from chain stretch. If the chain is loose That means the pull side has to be longer. If it is longer that means there is a change in timing. Take the tensioner off and push one side then the other. You will see the cam sprocket move. Movement is timing change. It's a no brainer if you really think about it. I am only stating what I see after seeing many motors done at our shop.
If you can still get them, what brand features them? Iwis maybe, mostly see "rollon" chains. I had used those aussie sets for a while but the chain stretched in very short amount of time.. so I put a tensioner on it. The mancini billet set seems legit. Had it on my 410 solid roller motor...no stretch! Unless they changed something...that's a killer set.what mo said
german and english renolds chais and Iwis
hole in the cup plug and the bolt if any rpm
