earthmover
in the tire smoke
comp cam 306 mag
110 lc
106 intake centerline
306dura
260@50
555/555 lift
comp cam xs282s
110lc
282/290 dura
244/252 @50
520/544 lift
right now the comp cam xs282s is in the motor and runs pretty good 7.54 et / 1.67 60' and 89.0mph still need to workout some susp. problems i think...anyway the 306mag pretty close with alot of issues..the motor had timing problems which always ran hot 180/190,blown head gaskets and could never get the carb to work it ran a best of 7.70 et and 1.77 60' and 89.9 mph with all the problems..to solve the problem put in a new chain still had slack had to put in the new tensioner and problem solved. now just thinking out of the box if i could have hooked a little better with the 306 mag. like it does with the 282 it should be faster right...so do you think that if cam 2 was back in and all problems worked out like now it would be the better cam????just looking for what some of the more exp. would think on this.....8)
110 lc
306dura
260@50
555/555 lift
comp cam xs282s
110lc
282/290 dura
244/252 @50
520/544 lift
