2009redrt
Member
For small block. Following cam is used but retains all original specs. $100 and buyer pays shipping.
Brand: COMP Cams
Manufacturer's Part Number: 20-717-9
Part Type: Camshafts
Product Line: COMP Cams Drag Race Camshafts
Summit Racing Part Number: CCA-20-717-9
UPC: 036584081753
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 4,800-7,800
Intake Duration at 050 inch Lift: 275
Exhaust Duration at 050 inch Lift: 284
Duration at 050 inch Lift: 275 int./284 exh.
Advertised Intake Duration: 308
Advertised Exhaust Duration: 317
Advertised Duration: 308 int./317 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.658 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.661 in.
Valve Lift with Factory Rocker Arm Ratio: 0.658 int./0.661 exh.
Lobe Separation (degrees): 108
Intake Valve Lash: 0.026 in.
Exhaust Valve Lash: 0.028 in.
Computer-Controlled Compatible: Yes
Grind Number: RX308R-8
Brand: COMP Cams
UPC: 036584081753
