Building a 5.9 Magnum fresh short 9:1 comp Eddy Magnum heads minor cleanup Eddy airgap intake(dual plane) 750 Demon carb 1 5/8 longtime. 518 trans 2500 conv with lockup. 3:55 gears. Car has power brakes is a pro touring type build with big brakes and all the handling tricks you can do. Car goes to the dragstrip 2-3 times a year is 98% street driven. Looking at a few off the shelf cams Comp xe274hr or the Lunati 20200715 or 20200711. I have 1.7 Harland Sharp Stock 1.6 rockers &1.5 Scorpions. Opinions on real world experience please. Max lift would be 565 based on piston to valve clearance. Leaning towards the Lunati 20200715 with the 1.7 rockers puts it at 550 lift and 213/219 @50.
Thanks mike
Thanks mike
