71DodgeDemon340
can anyone that has a edelbrock performer intake measure the thread depth of the carb mounting holes? Thanks for any help. Need to know how long of studs i need without having to pull the carb off
3/8 is plenty.can anyone that has a edelbrock performer intake measure the thread depth of the carb mounting holes? Thanks for any help. Need to know how long of studs i need without having to pull the carb off
3/8 of bottom thread for the carb mounting side is plenty....how thick the spacer is, plus heat shield, plus gaskets, plus around 7/16 for the carbs base plate...then figure the nut, washer...and get some that are about 4 threads longer than all those added up. Good luckThanks mopar but i meant i need to know how long of studs i need to fully thread into the intake, im looking at buying a carb heat shield and spacer and studs will make it 100% easier to locate everything plus the three gaskets. I will be screwing tge studs all the way in and then using nuts to hold everything
Right but i want to be able to thread the studs all the way into the intake then set everything down on it.
