can i combine hood pins and stock hood latch?
mshred
The Green Manalishi
Hey guys,
Id like to pick up a set of chrome hood pins for scamp (non lanyard style) and was wondering if I will still be able to use the factory latch to open and close the hood...I shouldnt have any problems using both should i?
thanks Sid, figured i could, but just wanted to double check
youll have to pull the pins first so the spring can lift the hood when you pull the latch.
yes i realize that...I was more concerned with closing it actually... but that should be fine too-slam the hood shut, then put the pins into the posts
Hey guys,
Thats how they were from the factory. You will now have three different latches on your hood. That thing ant coming off. LOL I got sick of taking the hood pins out, then hiting the first latch then trigering the third safty latch. So I took off the two factory latches. I don't remember but I think I took a good 2-3 pounds off the front end like that.
