Can I reuse oil pump spring
Big Block A body Tech
  1. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    9:35 AM
    I am putting on a milodon oil pump on my 400, can I reuse or do i need to use a spring in my new pump. Just what does the spring do since there is no diaphram.
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    17,751
    5557
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    9:35 AM
    .................any pump i've seen comes with the spring installed already.......spring controls how much pressure the pump can build.........kim......
  3. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    9:35 AM
    So I guess using the old spring would not be a good idea on a modified stroker. I will have to contact milodon and ask about the missing spring or if that is something I need to buy according to what pressure i want.
  4. bOb shingler
    bOb shingler Well-Known Member
    3,250
    163
    Jun 8, 2007
    warrenton, north carolina
    Local Time:
    10:35 AM
    if you lost/don't have a pump spring and have an old one you can use it.
  5. rumblefish360
    rumblefish360 So close, yet so far away FABO Gold Member
    39,972
    11516
    Jun 21, 2005
    New York, on a Island
    Local Time:
    10:35 AM
    High pressure springs in oil pumps are more often used in high rpm scream/drag race machines. In a stock to high performance builds, there is no need for this power robbing addition.
  6. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    9:35 AM
    Well I talked to milodon and they have an adjustable regulator that threads into where the spring goes and it comes with a new spring so I think that is the route I will take. Doing so i will be able to adjust to what ever pressure i want. Thanks All
  7. bOb shingler
    3,250
    163
    Jun 8, 2007
    Local Time:
    10:35 AM
    reaching it to adjust it is a trick.
  8. sireland67
    sireland67 FABO Gold Member FABO Gold Member
    9,467
    3688
    Oct 27, 2010
    WV
    Local Time:
    10:35 AM
    I have a new MP spring still in its original package, pm me if interested.
  9. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    9:35 AM
    Thanks for the offer but i want to try the adjustable one first. Reaching it as Bob stated might not be to much of a problem because my inner fender wells are custom made, flat and removeable BUT i haven't got the motor back into my 63 valiant yet--soon as I get my lower pully back from the powder coater I hope to.
