Can the bubbler steering coupler upgrade handle the heat?
shifty
New Haven county Ct.
I got my hands on the steering coupler updated rubber cover instead of the metal cover with the tabs you pean over, my header tubes are 1/4" away if I run this without the hose clamp, I didn't know if they were a silicon type , I'll need to update with a photo shortly
So I bailed on the new style rubber coupler cover
Due to heat / headers concerns, I I stalled the spring clip but can't clip it over the roll pin on that one side
[/IMG]
If you look at the illustrations in the ebay listing that was linked you can see the roll pin needs to be nearly flush with the surface of the coupler housing.
I tried 2 supplied roll pins out of 2 different kits and they both bottom out I believe, is there a stop or should I keep trying
