The bolt pattern and carb gasket should be the same. That's going by the gasket application, which some manufacturers show being the same from 1960 well into the 1970s. A BBD is a BBD, even when it's a Holley (or in the case of my '71 Challenger, a Rochester!). They all have the same bolt pattern and approximate throttle bores.
