car dosnt seem to be getting power?
ironmonkey
georgia
I went out to start my 73 duster 318 after it snowed. It started right up and idled like normal i went inside to get something and i heard the car just turn off. I then tried to turn the car on again but car has no power? starter doesnt turn, lights dont come on i checked the battery it was bad (dead cell) replaced the battery and still nothing? any one know what i can check?
Thanks for the help
William
Ya think it could have burnt something out in the Starter relay ?
The alternator was working hard all the time I bet.
The above won't cause the problem
If you have NOTHING and you just changed the battery, that's where I'd start.
Start with the BASICS
Take a test lamp or meter, and hook to the battery block. Turn on the headlight switch, turn the key to run and turn on the heater blower. THESE WILL CAUSE A LOAD which will help you find the problem
Hook the hot lead of the lamp / meter to the hot cable clamp. It should light. If not, you have a battery/ cable problem
If not, probe to the battery hot post. If not, you have a battery or GROUND cable problem
Hook the test lamp DIRECTLY to the two battery posts. It should light. If not, you have a battery problem
Hook the test lamp back to the engine block, hook the hot lead DIRECTLY to the battery NEGATIVE post. If it lights, you have a bad ground cable.
BACK TO START
Hook the lamp to block, probe to hot battery cable clamp at battery. If it lights, so far, so good.
Move the probe to the hot cable eyelet end, wherever it goes (starter?) It should light. If not, you have a cable / connection problem
Move up to the big stud on the starter relay. Lamp should light. If so, you probably have lost the fuse link and or the main feed through the bulkhead.
ok so i found a broke wire fixed it now it trys to crank but dosent start like it is not gettting spark? anyone know what i can check now?
thanks for all the help
the three big plugs that plug into the firewall it went to the middle plug the wire had a fuseable link and the wire had cancer and finally fell apart oh the other end went to the starter relay. i put a inline fuse link back in.
the ballest resistor that is the square ceramic box with 2 plug going to it Correct? what should it read?
i put a meter to the coil and nothing is getting to it?
thank you for all the help guys
I would guess that either you have further problems with the bulkhead connection, or that you somehow did not get it back together quite correctly, and now the ignition feed is not getting power.
Diagrams:
http://www.mymopar.com/downloads/1973/73ValiantA.jpg
http://www.mymopar.com/downloads/1973/73ValiantB.jpg
Because it cranks--does it crank OK with the key, or are you "jumping" the relay?
If it cranks OK with the key, this indicates that the ign switch is getting power
The only real possibility is that the contacts in the switch are bad for "ignition"
or the short wiring from there to the bulkhead
or the bulkhead itself
or the short harness form the bulkhead to the resistor.
what size fuse is the fuseable link that runs from the starter relay to the plug on the bulkhead
