Slant6Gilman
Member
i just got a 600 cfm holley that was barely used and i got it for 150$. i want to build my slant but i am wondering how much i need to build it to use that
Yes I know but I pretty much stole the thing and I'm just kinda wondering what people have done to run that size of carbyou gota Volare as well..... I need to get back on mine. been sitting dormant way too long.
you dont build an engine around a carb, that is totally backwards.
It all really depends uponYes I know but I pretty much stole the thing and I'm just kinda wondering what people have done to run that size of carb
A 600 cfm carb is too much for a street driver slant, if it is a double pumper, you will be very unhappy. If it is a VS you might barely get away with it, but I wouldn't bet the farm.
10-4 thank you buddyIt all really depends upon
1) your total budget, for the engine, transmission, rear end, auxiliary systems like brakes, cooling to name a few.
2) your plans - goals for the car, is a daily driver, a full time race car, drags or auto cross?
Figure out what you want to do with the car then see if that carb fits in. If it does not, move it on to someone that can use it.
I once bought a hat that was too small, so I went to a surgeon and had him reduce the size of my head.you gota Volare as well..... I need to get back on mine. been sitting dormant way too long.
To Run that 600 CFM, Cam swap 264-268 Duration, Head Porting/ Milling 9-9:5 CR, Headers 3.23-3.55 gears. On a stock slant six Two Barrel Carter BBD is the ticket, I have found that a four barrel on a stock slant will run slower than a two barrel. Once you your increase Compression the four barrel really shines through. Good luck!
thats what i was planning to do. im going to do cam, headers, intake, shave the head, and maybe bore it out a little.To Run that 600 CFM, Cam swap 264-268 Duration, Head Porting/ Milling 9-9:5 CR, Headers 3.23-3.55 gears. On a stock slant six Two Barrel Carter BBD is the ticket, I have found that a four barrel on a stock slant will run slower than a two barrel. Once you your increase Compression the four barrel really shines through. Good luck!
would a dremel work or is that what he used? or would it be better just to find some headers?Not much. It'll take a 600 ok. You'll need to upgrade the exhaust "somehow". Either add headers or bore out the exhaust manifold like I had my friend Freddie do for me. You can read about it here:
Exhaust Manifold Mod
It's not hard to do, but I chose to let Freddie do it because my skills with a hand held grinder suck. I never would have thought there would have been that much meat in the outlet of a slant exhaust manifold but there is.
Also, a nice high flow air cleaner won't hurt. While internal engine mods are not necessary, it won't hurt to have the head milled, re-cam it if you want to go that far. It just depends on how far you want to go. As long as you use a vacuum secondary 600, it'll be fine as you can adjust the secondaries with the diaphragm springs.
Yup, headers,cam,comp,intake,carb will wake that slant up, also dont forget to recurve the distributor as well.thats what i was planning to do. im going to do cam, headers, intake, shave the head, and maybe bore it out a little.
Depends on how long you want to be holding that dremel. Sure it will work but it would be like cutting 10 acres with a manual reel push mower. Kinda the opposite of the 600 cfm on a slant 6 overkill.would a dremel work or is that what he used? or would it be better just to find some headers?
But would headers work better then stock cut out a littleFreddie had two hours in the one I linked to. Headers are what? over 400? It's a decision you're gonna have to make.
But
But
come on man, do some hotrodding
Slant 6 Six Dodge Plymouth Mopar 225 Exhaust Manifold Header Flanges 1/2" thick | eBay
Small Block Chevy Header Kit, 1-5/8 Standard Port, 3 Collector | eBay
you got a welder, right?
If you're talkin to me, of course I have a welder.....and the know how to build headers. I don't want headers. I want a manifold.
