mullinax95
The previous owner installed a spread bore Eddy intake and a Eddy Performer carb without any spacers. I kept having hot starting troubles and installed a square plastic 1" spacer which help fix the hot start problem.
But noticed today while the motor was running that it was whistling noise. Found out the carb gasket was leaking. This is the order in which I had the gaskets installed:
intake
square bore gasket
spacer
spacer gasket
carb
It was leaking around the intake and the square bore gasket. What do I need to do to correct the problem. I am going to get two new regular gaskets and try that but just wondering if this correct. When I bought the spacer I bought it to macth the carb not the intake. The previous owner had a thin metal gasket which was not spread bore between the carb and intake and it did not leak.
intake
square bore gasket
spacer
spacer gasket
carb
