Carb id (?)
bighammer
Northwest Oregon
I was planning on getting a new carb for when I get my 360 swapped over. But I have had such good luck with it on my 318, I may try it out on the 360. Can anybody identify which Carter AFB it is? Cfm?
The majority of Carter comp series carbs sold were probably 750's. I see some numbers on the pass side front mounting tab, what are they?
Check the numbers on the mounting tab, where your vacuum line runs to the distributor.
The carter I had was a 625 cfm.
See that stamped number on the passenger side front corner of the base plate? Me either. Get that number and look it up online. You'll find out what it is.
What are you blind? I can read it from here LOL
Lol, I didn't see it when I looked at the car, now it looks big as day!
6905s: 600cfm Too small for a mild 360?
That carb should be real responsive on a mild 360.
