1. TUT
    TUT New Member
    2
    0
    Mar 23, 2021
    Daylight, TN
    Local Time:
    3:13 AM
    340-416 what is better carb or did 90% track 10% street
  2. RammerJammer75
    RammerJammer75 Well-Known Member
    1,287
    1593
    Aug 28, 2020
    Kingsport, TN
    Local Time:
    4:13 AM
    I would go with the one that you have the most knowledge of, fits in your budget, and will be the easiest for you to tune.
    • Agree Agree x 2
    • Like Like x 1
    • autoxcuda
      autoxcuda Well-Known Member
      7,064
      1315
      Apr 6, 2007
      Local Time:
      1:13 AM
      90% track...
      ...carb
      Reliable, fixable, makes more HP than common plug and play TBI setups, will always be able to get parts for them....
      • Agree Agree x 3
      • AJ/FormS
        AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
        20,778
        8160
        Jan 19, 2014
        South-Central Manitoba,Canada, 900ftelevation
        Local Time:
        3:13 AM
        and keep a points distributor in the trunk, so that if you get hit by an EMP, in a couple of minutes, you can still have a getaway car,lol.heck on the NWO
        • Like Like x 2
        • Agree Agree x 1
        • volaredon
          volaredon Well-Known Member
          610
          168
          Feb 28, 2010
          IL
          Local Time:
          3:13 AM
          No debate needed. CARB
          • Like Like x 2
          • 318willrun
            318willrun Utube channel 318willrun
            17,008
            19068
            Sep 13, 2013
            I'm here
            Local Time:
            3:13 AM
            Carb guy myself, on the older stuff at least
            • Agree Agree x 4
            • Bewy
              Bewy Well-Known Member
              532
              286
              Jan 1, 2021
              Australia
              Local Time:
              6:13 PM
              Carb or EFI.
              Like asking which football team is best....
            • gregcon
              gregcon Well-Known Member
              683
              683
              Dec 20, 2009
              Local Time:
              3:13 AM
              A carb makes sense in this instance....you won't be using the vehicle enough to justify an EFI system.
              • Agree Agree x 2
              • Ivoryk3ys78
                Ivoryk3ys78 Well-Known Member
                180
                90
                Jul 5, 2018
                Oregon
                Local Time:
                1:13 AM
                Cab with wideband 02 in the exhuast. You can dial in your A/f for wide open throttle (12.5 area) square jetted with a power valve block off installed. You can then lean tune for the street if you want by finding the primary jet that gives a good cruise A/F (like mid 14s) and then increase the power valve restrictor channel size back up to square jet size with the power valve.
                Also with the carb you get the fuel cooling from the venturi velocity increase. Good for power.
                • Agree Agree x 1
                • Nat
                  Nat Well-Known Member
                  588
                  321
                  Jun 11, 2019
                  Netherland
                  Local Time:
                  9:13 AM
                  wouldn't yiu need and old time voltage regulator and what about the ECU wouldn't the EMP knock those out as well /
                • AJ/FormS
                  20,778
                  8160
                  Jan 19, 2014
                  Local Time:
                  3:13 AM
                  I don't know anything about EMPs, except that it is said that an EMP will knock out anything electronic that has electricity running thru it or power to it, at the time of the pulse. So yes the electronic regulator and ECU would be toasted.
                  But
                  a points distributor does not use the ECU, and
                  you may have noticed that a good working regulator is not required to make or keep a car running; it will start and run just fine with the thing unplugged. However, without the charging system working, the battery will eventually get low enough to either not start the car, or not keep it running. You can get around that by full-fielding the alternator with the engine running, from time to time, to maintain the battery at full or near full charge.
                  But if the EMP takes out the alternator (not likely IMO), then yur walking.
                  I'm still having a hard time believing that an EMP can exist, or that it can do large scale damage if it did. But then; I do believe in;
                  giants and monsters, talking donkeys, special delivery by whale, and dead men walking, so .................
                  • Like Like x 1
                  • MrJLR
                    MrJLR Built, not bought FABO Gold Member
                    5,148
                    5441
                    May 14, 2015
                    Chino, California
                    Local Time:
                    1:13 AM
                    EMPs are very rare and very real.
                    :lol:
                    Jeff
                    • Agree Agree x 2
                    • Like Like x 1
                    • Ron816
                      Ron816 Well-Known Member
                      362
                      302
                      Nov 15, 2019
                      Quincy, MA
                      Local Time:
                      4:13 AM
                      A well tuned carb is a lot cheaper and runs just as good, I have a carter AVS and runs flawlessly and also gives me a good feeling that I kept what the car was born with
                      • Agree Agree x 1
                      • Mattax
                        Mattax Just the facts, ma'am FABO Gold Member
                        11,951
                        7678
                        Feb 7, 2013
                        Phila. Pa
                        Local Time:
                        4:13 AM
                        To properly support EFI, the electrical system needs major alteration. The original design isn't really appropriate, although people have been known to crutch it. So weigh that when considering whether carb or EFI is for you on this project.
                        • Like Like x 1
                        • Thanks! Thanks! x 1
                        • QuickDart360
                          QuickDart360 Well-Known Member
                          1,327
                          524
                          Apr 5, 2014
                          San Antonio
                          Local Time:
                          3:13 AM
                          I love my thermusquad! Sitting pretty on top of a Victor 340 intake on my hot 360 it scoots from 0 to upper rpms with no hiccups!! Just bam!
                          • Like Like x 2
                          • Bewy
                            532
                            286
                            Jan 1, 2021
                            Australia
                            Local Time:
                            6:13 PM
                            Love 'dem TQs!!!
                            • Agree Agree x 1
                            • Nat
                              588
                              321
                              Jun 11, 2019
                              Netherland
                              Local Time:
                              9:13 AM
                              TQ is a great carb i got the street demon 850 a sort of tq looking carb works well
                            • Nat
                              588
                              321
                              Jun 11, 2019
                              Netherland
                              Local Time:
                              9:13 AM
                              i agree my 340 ran better with the orig AVS than the holley that replaced it . plus having the orig carb just feels better
                            • K.O. SWINGER
                              K.O. SWINGER Meeting in the alley since 1976
                              1,884
                              1318
                              Nov 18, 2010
                              oregon
                              Local Time:
                              3:13 AM
                              I'm with the carb people on this one for sure. Which carb well that's a whole another different conversation.
                              • Agree Agree x 1
