carb/ starting issues
lebdog74
Active Member
Osterburg, PA
i have a 74 duster 318. edelbrock carb/intake setup. after staarting and running it for awhile if i shut it off and restart within a few minutes most time it will fire right up. but if it sets much longer than that i have to crank it and crank it pump the throttle and sometimes choke it. have been told a spacer between the carb and intake would solve the problem. but not sure of this. they offer 1" and 2". open hole and 4 hole spacers. not sure which one if indeed this is the problem. also have notice the fuel filter will empty if it sets awhile. any help would be great thanks
