While my carb is off getting rebuilt, I need to order a new gasket and some other items.........
Which is better and Why:
Carb mounting bolts or studs?
I use a flat washer on the carb flange. You can use a lock washer or a toothed washer under the nut as well.Thanks for all the info, I appreciate it
The bolts that were previously used to mount the carb are 5/16-18 and the threads are 3/4" long
The thickness of the carb flange is 1/2" and the depth of the threads in to the manifold are 7/8"
SO, 1-3/8" total but thats max also with bottoming out the studs into the manfold
With carb mounting studs, are washers always used ontop of the carb flange?
the intake thread holes are 7/8" deep
The thickness of the carb flange is 1/2" thick
So that is 1-3/8" total but that's max also with bottoming out the studs into the manifold and without having any threads on top for the nuts and or washers
I have bought a lot of old Edelbrock manifolds. (LD4B and D4B's) If everybody used studs the carb and thermostat threads wouldn't be all stripped out. I recommend studs for any aluminum fastening unless it has steel inserts.I've used both and it's never made any difference ~~ except studs do make it easier to mount the carb straight the first time. As Pishta said, you're not putting any real torque on them so stretching really is not an issue. And yes, a washer and a lock washer on the carb flanges IMHO.
I just put heli-coils in everything aluminum when they are new. You'll note that Edelbrock, for one, puts heli-coils in all the threads in their aluminum heads. Working in the aircraft industry, I have noted that most threaded holes get heli-coils installed at the OEM (brand-new parts).I have bought a lot of old Edelbrock manifolds. (LD4B and D4B's) If everybody used studs the carb and thermostat threads wouldn't be all stripped out. I recommend studs for any aluminum fastening unless it has steel inserts.
Always use studs in anything aluminum... It’s wise to replace factory oem transmission pan bolts with studs for the same exact reason. Over years of maintaining a carb, transmission, etc. You can avoid ruining an intake or transmission by using studs.
