Carbon tracking through rotor. More HEI woes.
Electrical and Ignition
  1. iScamp
    iScamp Well-Known Member
    222
    127
    Nov 1, 2012
    North Carolina
    Local Time:
    4:38 PM
    If it were up to me, I'd go with a dual points distributor. But, bro owns the car and says HEI stays. Now that I think about it, I might keep a points distributor in the trunk. Vacuum sealed package and a distributor wrench.
    • Like Like x 1
    • Dana67Dart
      Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
      4,327
      2638
      Jul 16, 2017
      Northern Colorado
      Local Time:
      2:38 PM
      Really thinking outside the box here.
      Make a dist shaft out of a non electrically conductive material.
    • iScamp
      222
      127
      Nov 1, 2012
      North Carolina
      Local Time:
      4:38 PM
      I was thinking of making a ceramic distributor rotor. That's MY idea and I'm gonna patent it. :lol:
    • Dana67Dart
      4,327
      2638
      Jul 16, 2017
      Northern Colorado
      Local Time:
      2:38 PM
      I think David Lee Roth said it best...
      "We're running a little bit hot tonight" tone down the output voltage
      • Like Like x 2
      • jbc426
        jbc426 Well-Known Member
        1,811
        638
        May 30, 2007
        West Coast
        Local Time:
        1:38 PM
        Smart move. It's good to have options out on the road. Make sure you add a ballast resistor and a coil to the bag.
        • Agree Agree x 1
        • iScamp
          222
          127
          Nov 1, 2012
          North Carolina
          Local Time:
          4:38 PM
          Testing on the 340 was delayed by a bunch of other projects.
          Here is what we found this past weekend:
          Average gap between rotor tip and button in the cap was .120". We extended the brass rotor tab and now have an average gap of .030".
          Drilled a hole in another cap and checked rotor phasing with a timing light. Basically, the phasing is way off. The rotor is pointing at plastic, not the cap button. We are looking for a reluctor that has the proper phasing. Ehrenberg sells them on Ebay sometimes. Or I may have this one machined with a new keyway.
          Got to get back to the other projects, so another progress report will be a few weeks away. Thanks, again FABO members.
        • Dana67Dart
          4,327
          2638
          Jul 16, 2017
          Northern Colorado
          Local Time:
          2:38 PM
          Screenshot_20200602-221046.png The reluctor I have has two keyways one for big bock And one for small block, any chance you have it installed on the BB keyway?
          Note the arrows for rotation direction
        • 67Dart273
          67Dart273 FABO Gold Member FABO Gold Member
          42,931
          10504
          Oct 14, 2010
          Idaho
          Local Time:
          1:38 PM
          ^^I nearly mentioned this.........."rotor phasing"
        • 67Dart273
          42,931
          10504
          Oct 14, 2010
          Idaho
          Local Time:
          1:38 PM
        • iScamp
          222
          127
          Nov 1, 2012
          North Carolina
          Local Time:
          4:38 PM
          Mine has the two keyways. It's installed correctly. We tried to install it in the big block location but, that made the phasing even worse.
        • Demonracer
          Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
          3,303
          1288
          Jan 31, 2010
          Cleveland, Texas
          Local Time:
          3:38 PM
          If your brother insists the GM HEI stays, tell him next time it gives him problems to; A. Call AAA, B. Fix it himself, C. Change the hybrid stuff back to Mopar.
        • 67Dart273
          42,931
          10504
          Oct 14, 2010
          Idaho
          Local Time:
          1:38 PM
          Have you tried switching pickup wires?
        • iScamp
          222
          127
          Nov 1, 2012
          North Carolina
          Local Time:
          4:38 PM
          A. Already had to do that when I was driving it.
          B. I can't let it whoop me.
          C. He's heard so much good about HEI, that he won't give it up.
        • iScamp
          222
          127
          Nov 1, 2012
          North Carolina
          Local Time:
          4:38 PM
          Somewhere I found information about polarity of the pickup wires. They are wired correctly. I don't want to swap them 'just to see' because I think it will damage the module or cause a weak spark. I think we are on the right track with rotor phasing and rotor gap. There are some guys here on FABO that rave about HEI. I think it was Trailbeast that sold HEI kits for Mopars. So, we're not giving up.
          But, any long trips with that car and there's gonna be a points distributor boxed up in the trunk.
        • 67Dart273
          42,931
          10504
          Oct 14, 2010
          Idaho
          Local Time:
          1:38 PM
          No, you are thinking wrong. All it does is change the spark position. It's an AC signal. Wired one way, the first pulse is positive, the second negative. You swap them, they are reversed, and displaced in time. Swapping them IS THE WAY to find out if that is the cause of rotor phase problems.
          Wire color is sometimes wrong. Swap them and see, and make darn sure the reluctor is correct
          • Agree Agree x 1
          • Krooser
            Krooser Reform School Graduate
            2,327
            1859
            Jul 19, 2015
            Central Wisconsin
            Local Time:
            3:38 PM
            Ditch the Blaster Two coil....
            • Agree Agree x 1
            • iScamp
              222
              127
              Nov 1, 2012
              North Carolina
              Local Time:
              4:38 PM
              Interesting. Yeh, what I read was a certain wire color should go to the small connector on the module. Worth a try, with the swap.
              Reluctor is installed correctly.
