Removing the headliner is fairly easy if you take your time. Remove all the trim, the review mirror, sun visors, remove the dome light assembly, and the seat belt bolts/trim if you have the shoulder harness. Pop loose the sail panels. It is really easy if the seats are out but if they are still in, tilt forward or back depending on the seat. Roll all the windows down, and the headliner will fit though the windows with a little jockeying around. It sounds like a lot of work, but I know how it works because I took mine out to paint it. It goes in easy, but have someone help you put it back in, it sucks when you are doing it by yourself.
Dante's looks pretty good.
Hope this helps.
