67formula S
Member
Just wondering if the carpet is supposed to go under the gas pedal or not. Any help would be appreciated thank you in advance.
If I remember correctly, the gas pedal assembly has a mounting pad that bolts directly to the floor with a gasket between the bracket and the floor.Just wondering if the carpet is supposed to go under the gas pedal or not. Any help would be appreciated thank you in advance.
On our 67 there is no carpet up by the bracket. Bracket is mounted up by footwell and the pedal "floats" so to speak.
Just don't put it on top of the pedal.Just wondering if the carpet is supposed to go under the gas pedal or not. Any help would be appreciated thank you in advance.
