gdizzle
This is a freshly rebuilt (2 months ago) Carter BBD 2bbl carburetor. Came off an old 70s Dodge running a 318. I rebuilt it and tested it on my 66 slant, and it fired up and ran. I did not adjust the idle so that will need to be dialed in once installed. It does have the Sol-Vac although the wire has been cut and it's only function at this point is to manually set the stop for curb idle adjustment. I do not know if the Sol-Vac would work if you wired it in.
This is a great option if you are wanting to swap from 1bbl to 2bbl. Foil tag is present (#8237S). This is not a Reman. $50 shipped. PayPal.
