gdizzle
This is a freshly rebuilt (1 month ago) Carter BBD 2bbl carburetor. Came off an old Dodge running a 318. I rebuilt it and tested it on my 66 slant, and it fired up and ran. I did not adjust the idle so that will need to be dialed in once installed. It does have the Sol-Vac although the wire has been cut and it's only function is to set the curb idle adjustment. I do not know if the Sol-Vac would work if you wired it in.
This is a great option if you are wanting to swap from 1bbl to 2bbl. Foil tag is present. This is not a Reman. $40 plus shipping
