[SOLD] Carter Competition Carburetor Project
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
This is an older 9636SA Carter Competition 625 CFM carburetor. I am selling it as is. It is a project with a few missing pieces, but it is clean on the inside. I put a kit in it. It has a little surface rust on the choke flap and a little on the throttle plates and linkages, but it's not a POS. It will make someone a nice little carburetor once all the pieces are found. It is complete on the inside. Everything missing is exterior. The throttle shafts and bores are tight and everything moves freely. As stated, this is as is. It is a used carburetor with a fresh kit, but has some small pieces missing. The group of small pieces on the shop cloth is ALL that I have. A new comparable Edelbrock is right around $400. You may need to make adjustments once completed. Even change the float level for your application. In short, I'm not marrying you over a $75 dollar carburetor that needs a few small pieces. I would keep it myself, but I have a bungload of carburetors. Located in middle Georgia. $75 shipped to the lower 48.
Ok. Nevermind. I don't have the bench room so off to the dump it goes.
