keelhaul21
Member
I've got a carter afb comp. carb that I just recently rebuilt, and now fuel runs out of the primarys. There was another user with a simular problem, but he was using a holley. Anyway I'm pretty sure I just have the floats to high, (stock fuel pump). I used a eddy rebuild kit 1477, it wanted the floats at 7/16, 15/16. I set the floats according to the carter book I have which was 9/32, 15/16. Should I set the floats to the eddi specs?
Thank you for your time
