Look at the parting lines on the crank. Narrow, peak shaped, (sharp) = cast. Looks just like the molding lines in any cast plastic item. If the lines wide, and has a ground off appearance, it's forged.
Forged is a hot steel block placed in a mold and then the press comes and presses the crap out of it...leaves wide lines....cast is hot molten steel poured into a sand cast mold that has two halves...thus very fine skinny lines...just like he said about the plastic models..
