1969GTS340 Well-Known Member Joined Apr 13, 2014 Messages 758 Reaction score 245 Location Akron, NY Aug 6, 2017 #1 I want to swap out the center caps on my wheels from the large style used in 1972 to the smaller acorn style used in 1970. Is there anything about the rims that would prevent the center caps from being swapped out?
H22A4 Does anyone read this? Joined Aug 4, 2006 Messages 3,283 Reaction score 2,714 Location YVR Aug 6, 2017 #2 There shouldn't be... just a unscrew and screw on job. I doubt the factory would have created new mounting pattern for the different centre caps.
6pk2goDemon Mopar Mod Staff member FABO Gold Member Joined Mar 1, 2008 Messages 10,827 Reaction score 2,468 Location Arizona Aug 6, 2017 #3 The cone style centers will bolt right up to your wheels. I like that style better too & used them when running ralleys on my 72... Just make sure you get the correct bolt pattern centers for your application.
